메인 콘텐츠로 스킵하기
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
456 질문 전체 보기
loose connection prevents charging on MacBook Pro 15" 2008
Recent problem: the connection is loose to the magsafe power port, it's difficult to get it to charge unless I push and wiggle it till it seems seated, it stays for a few secs, but then releases itself and the connection is not good enough for recharge. I've managed to get it to stay after several attempts, but the problem will only get worse so want to get it sorted before it won't charge at all. Incidentally the magnetic plug is very hot too. Can I replace the magsafe power port easily?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Thanks very much for such a clear answer. Whether I am capable of working on it I'm not sure, but that's my problem, at least it looks as though there is a way of replacing it. Thanks once again.
의 답변
의견 추가하세요
1개의 답변
가장 유용한 답변
This should help.
MacBook Pro 15" Unibody Late 2008 and Early 2009 DC-In Board Replacement
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
lizzie 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 6
전체 시간: 283
