주요 콘텐츠로 건너뛰기
The Nikon D5200 is an F-mount DSLR camera with a 24.1 megapixel DX-format CMOS image sensor. The D5200 has a maximum resolution of 6000x4000 and is capable of 1080p video recording.
31 질문 전체 보기
Problem with image size
A friend has this camera and so do I. We both have the image size set on RAW and L. My photos have a high resolution of 6000 x 4000 and hers are at 640x427. We cannot figure out why her photos are so small. Would this be a camera defect?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
When she uploads the photos in Lightroom, all come in at 640x427 297Kb. She is not using video.
Your Lightroom is probably set wrong. That's thumbnail size. Change her upload settings to full resolution.
댓글 달기
답변 1개
선택된 답변
That resolution isn't even possible with that camera. However, 640x424 is a supported video resolution. Are you sure your not looking at the video setting? If not, what is the resolution of your pictures based on what your computer says? Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Also, you need to try a system reset on the camera. It should be in the menu with the wrench.
I might not have the size exactly right, but all of the photos she uploads into Lightroom are a small pixel size, and about 297KB. All the settings on the camera look right, image quality is RAW, and size is L. But the photos upload very small.
Something is wrong. What resolution is the image size set to?
댓글 달기
귀하의 답변을 추가하세요
abutts22 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 218
