주요 콘텐츠로 건너뛰기
수백 가지 광학 디스크 드라이브 수리 및 분해 안내서.
30 질문 전체 보기
wont eject cd but reads fine
Mechanical problem with Pioneer superdrive. (PIONEER DVD-RW DVR-K06A)
2007 iMac intel.
Disc tries to eject but fails. (can hear it try to eject)
Re-mounts and reads disc fine but can't get it out.
I followed steps to remove optical drive and removed disc successfully.
Like an idiot, I stuck in a different disc thinking it was the old disc and got it stuck too.
What is stopping the CD/DVD from being ejected?
Is there something I can look for like a bent piece or something?
Or maybe a spring that's popped off?
Thanks!
Wyndell
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 10개
선택된 답변
No one I know of has been able to successfully repair one of these. You'll probably spend hours and hours fooling with it to no avail and risk damage to your machine taking it apart over and over. Bite the bullet and pop for a $50 replacement drive. Here's one: http://www.gainsaver.com/catalog/Detail....
You already know how to install it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
Quick check:
Initially, you could check if the disc budges at all inside the slot when the drive is trying to eject it. Shine a light and take a look. This is to make sure the disc isn't bumping against the inside of the iMac's or the drive's casing.
Thorough check:
Seeing as you already followed steps to remove a disc manually, you probably have taken the drive out of the iMac and opened the drive itself.
I suggest running the drive while it is outside the Mac and with its (the drive's) covers off. I am not familiar enough with that model iMac to tell you how to do this. All you need is a way to power the drive outside the iMac and make it eject.
Once you can see inside the drive, attempt to eject and observe what it is doing.
Usually drives like these have a small motor that is tasked with lowering/moving the spindle the disc is sitting on and pushing the disc out. From your description, the motor is working, but some part it uses to push the disc with, might be stuck.
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thanks Jakub,
Impossible to see inside even with a light because of the protective felt lining
of the disc slot. Will have to take it apart again and see if there is a way
to power it up with the drive out. If you look at the instructions for optical drive replacement in the "iMac Intel 20" EMC 2133 and 2210 Repair Manual" section. It does not look too promising. So much has to be unplugged just to get the drive out, and the power/data cable for the drive is pretty short. I may just remove the felt long enough to see what I can see.
Thanks
댓글 달기
Try shutting down the computer, let it cool down, reboot and then try again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Have done that a dozen times. Been through all the disc eject routines. This is definitely hardware related.
There is something wrong with the eject mechanism in the drive itself.
I'm just trying to see if anyone has been able to repair one without replacing it.
Thanks
댓글 달기
If you need to replace, there's a procedure on this site:
iMac Intel 20" EMC 2105 and 2118 Optical Drive Replacement
However, I've found this works too as the problem is particularly only to some disks.
http://www.youtube.com/watch?v=krfh8wlhN...
jon
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same problem on my mac mini. Looking at it open, whilst running, I could see that the spindle is not releasing the disc. It's either sticking on to it more than it used to, OR (as I suspect) the lowering of the spindle (which is the motion whereby the disc is released) has lost some power in it's travel or thrust or whatever.
It's not the linkage 'arms' that have little wheels on to guide the cd out. I know this because I manually popped the cd off the spindle before ejecting it via the keyboard.
Is this common and can it be fixed I wonder?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
similar problem with a small pc. the DVD is mounted virtically and will not open when eject is pushed. however, it works fine if the computer is on it's side so that the dvd is horizontal.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
my 2007 imac 24" desktop has started to have the same problem ejecting discs - i can hear the whirring, then the disc remounts and is recognized. went thru this with two discs, thinking that perhaps the disc was the problem. tried the entire list of disc ejecting procedures listed in apple support several times and eventually ejected both discs. finally decided to not use the drive.
after reading the very well written and photographed descriptions of the methodology for replacing an optical drive, i've decided to buy an external drive and use it for the not-so-frequent occasions when i need to use a disc. (i'm not very tech savvy, altho i'm handy and might be able to manage the process, but it looks difficult and time consuming, and risky for someone who doesn't have experience with computer innards.) i've found, after some searching, a top loading drive (lite-on, sold on amazon) which i plan to buy, since the problem with the drives seems to be the mechanical eject mechanism, and a top loader will eliminate that problem.
this is a great site, and so many of the contributors have such impressive knowledge. thank you.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I now have the same problem too.
Looking at it closely when it tries to eject I can see that there is a sort of mechanical latch in the front, center of the slot that closes the slot when the disc is spinning (maybe it's a kind of protection).
When I try to eject, the latch starts to move down but fails to completely get out of the way when the disc is pushed outside. So it happens that the disc bounces on this small latch and returns inside the drive again.
Then the latch is locked again once more and the disk is again mounted.
I successfully ejected the disc by helping the latch lowering during the eject process with a small plastic pick. I had to take particular care to synchronize my movement with the eject attempt from the drive.
So my conclusion is that either the mechanism that moves this small latch is worn to a point that it is unable to completely get out of the way at the right time, or it is bent somewhere and this prevents its correct movement.
Anybondy knows what I can do to fix it?
Apart from this the drive is working fine, is reading and writing everything correctly and that's why I'd rather keep it and fix this mechanical fault if possible.
Thanks.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It can be easily fix. It happens due loss of lubricants on track and dust.
Simply remove optical drive and open disc tray as you removed cd when it stuck.
Simply turn back it and you can see small track on both the corner of track. Clean both the track properly and lubricant it lightly. Randomly open and close the tray by hand it will lubricants from inside the gears also. Now install it back and try to use it. Definitely it will work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, I am looking for a lubricant and applicator that I can use to oil the gears at the side, underneath the loading tray. What kind of oil am I supposed to use? For me, nothing is bent or mechanically in the way, and the rubber band on the spool is clean. The tracks are loose and clear. It's just that the Mac is so old that the gears have become very sticky and tight. And actually, both trays are in the same condition.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Wyndell Earles 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 5,773
