Why is my radio not turning on?
whenever i turn on the car the time will flash on then turn off and my radio wont start up
좋은 질문 입니까?
좋은 질문 입니까?
First thing to check is the fuse.
해당 답변은 도움이 되었습니까?
@col_panek This is more of a comment not an answer. Also, the op said the radio flashed, assuming there is power going to it
I never assume anything.
Check that fuse #28 (& possibly #39) in the passenger compartment fuse panel are OK. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the fuse panel cover to gain access to the fuses. To remove a fuse use the fuse puller tool provided on the fuse panel cover.
Here’s an image from the owner manual to show you the fuse locations in the fuse panel.
(click on image to enlarge for better viewing)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 7
30일 전: 48
전체 시간: 6,632
댓글 3개
Did you push the power button on the radio?
Cameron 의
yes i did but still off
Tsoxmonto Tsokos 의
I have a 2010 Ford Focus SE radio won't come on What's . Show ever
jasonoverbey4 의
