DSi XL will not read any games
My daughter's DSI XL will not ready any games. Everything else works fine picto chat, pictures, and internet are fine just can't read any games. We have tried several games to make sure. Please help.
좋은 질문입니까?
좋은 질문입니까?
I was wondering if you have done a recent firmware update and if that precipitated your problem? Check all contacts and pins and make sure they line up well. Just checking on some firmware issues with this. May be you can give us some more information. Could be that your card reader is just not recognizing the games due to a)firmware issues or b) card reader not working.
이 답변이 도움이 되었나요?
My internet doesnt work and my dsi's game card slot and I dont know what to do. Which companies fix things like this?
My daughters dsi xl system was doing the same thing and we tried several different things and nothing worked. I just took it and shook it gently to see if maybe something was loose and it came right on... SN: (don't shake it like you hate it, you don't want to break it...lol)
이 답변이 도움이 되었나요?
Suggested troubleshooting procedure:
1.- Go to settings > Check your firmware version.
2.- If 4.1 or higher your flashcard could be not compatible (R4s, etc)
3.- Check with an original game
4.- If still not recognized open your DS
5.- Look for continuty in the Slot-1 pins and as well in the swtich that check if the game is inside (are the two contacts solder aside of the slot-1)
6.- If not having continuty or a bended pin your solution will be to desolder the slot-1 and replace with a new one.
Manuel / Montreal
Console Fix Parts
이 답변이 도움이 되었나요?
you just have to update youre system
based on my 2 year research
you have to update youre system
step 1
make sure you have a reachable internet connection
step2
open settings
step 3
activate system update
step4
this will take a lot of your battery so charge while there loading
step5
the result is
the game will once again be playable
comment your results in my facebook profile
rhez danielle
it has a profile pic of a pony
and im only 12
이 답변이 도움이 되었나요?
My internet isnt working, sooo..... not really helpful 2 me (unless you can tell me how 2 fix that as well)!
The likelihood of a bent pin is low unless someone jammed something in there. Typically what happens with these and all cart slots is they oxidize over time and that thin layer of essentially rust will prevent a good connection.
I just fixed a dsi xl that would not read cards by simply pushing the cart in several times quickly (50-100 times). This had the effect of cleaning off the oxidized parts and allowing the cart to fully connect. So before doing anything drastic - try this first - just may save you a costly repair.
Not sure about the firmware causes.
이 답변이 도움이 되었나요?
I accidentally jammed something into there...
And if I keep putting the card In and out really quickly, it just switches off. What does that mean?
I just fixed this issue on my son's 3DS-XL Purchased in Dec 2014. He said that a message saying the "The SD Card couldn't be recognized. Please end the game and start again." This started happening intermittently and now the card cannot be read.
I noticed that the 4th pin from the lock tab was dirty on the SD card. After cleaning with an eraser still no luck. Tried putting the card into this laptop and there were files on it. I tried a different card in the 3DS and got the same message. Then I snapped some pics of the card connector in the 3DS with my phone to try and get a look at the pins. The contact for 4th pin (clock) was corroded. It looked much lighter yellow than the rest of the pins. I got a micro-SD adapter and cycled it in and out of the 3DS about 15 times. I put the original card and the card was recognized and everything seemed to work.
In summary: If you are stuck with the "SD Card" message try push-in push out another card a lot to try and get to good contact again.
이 답변이 도움이 되었나요?
Has your daughter ever put the game in reverse? If so, the pins in the game slots are broken. It happened to my ds as well, and it can't be fixed at home , I'd recommend to look for a guy to fix it.
이 답변이 도움이 되었나요?
I meant that if she has ever put the game card in reverse into the game slot with pressure... then the pins that read the game card breaks...
The only EASY way to fix this: Find a guy to repair it.
See? I told you it was easy!
이 답변이 도움이 되었나요?
Try putting a clothing tag in the game slot alongside the game. It worked for me after a few tries.
이 답변이 도움이 되었나요?
지난 24시간: 3
지난 7일: 20
지난 30일: 84
전체 시간: 52,445
댓글 5개
when i go onto my game it just says menu with a questions mark and its been working fine all this time but i dont know about now
aman 의
Maybe they are just dirty try to blow in the slot if not blow on the game and if that doesn't work then you might want to get it looked at that happened to my friend too
Samara 의
hi I have a dsi when I put a game in then turn it on it does not see the game. can you fix it for me.
kellyjackson87 의
Whe never I insert my game card into my dsi xl's game card slot it won't read it no matter what, I've tried blowing into the game card slot,and I've paratcly tried every thing to make it work but it won't does that mean that the game card slot is broken and needs to be repaired?
Naomi Morrison 의
@Naomi Morrison well the only solution is to replace the slot.
dudewiththe101 의
