주요 콘텐츠로 건너뛰기
독특한 슬라이드 아웃 배터리 및 다중 하드웨어 확장 옵션을 지원하는 분리 가능한 I/O 모듈을 갖춘 LG의 주력 스마트폰. 2016년 4월 출시.
146 질문 전체 보기
Outer Screen Glass Replacement or Digitizer Replacement?
My daughter dropped her LG G5 and the screen is cracked. I've looked online and I see parts available are the Front Outer Screen Glass Panel Lens Replacement and the LCD display Digitizer Touch Screen Assembly.
Which one do I need to replace?
There only appears to be cracks on the screen. The touch functionality appears to be working fine even in the areas that are cracked, and all images appear to be displaying fine as well.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
https://www.youtube.com/watch?v=SyP_cEpp... Thats how to take it apart and the screen replacement link is in description. You need to replace the glass but separating can be a risky risky process and its best to just get the whole assembly
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Switching out the glass only is what I need to do also. From my understanding it's a very difficult task. Your better off getting the digitizer with glass combo. It's already attached for you and can be accomplished fairly easily. When people try to separate the LCD glass from the digitizer they end up damaging the digitizer, only a pro. should even attempt it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gerhard Guevarra 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 4,028
