주요 콘텐츠로 건너뛰기
GMC가 제조한 자동차, 트럭 및 SUV 수리 안내서 및 지원.
290 질문 전체 보기
Why my doors and window not working
I was working on my gmc envoy xl climate control when i put it back on for some reason my doors and windows do not work but with my fob im able to lock the back doors and liftgate but not the front can anyone help me?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
There are really 2 things to check. One is the fuses. Remove and inspect every fuse for is they are blown. If they arent, remove the climate control and check to see if you have any pinched or damaged wires. If you do, you probably need to resolder them, but if its not bad, you might get away with some electrical tape. If you find a blown fuse, replace it and it blows instantly, then you know there is a short, probably near the climate control as thats where you were messing around.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Cant find no wires there are so many of them and hard to get too there is power from the main terminal thats go into the master switch but nothing works i change it with a used one but still does the same thing
I checked the fuse they are not blown and the circuit breaker are working replaced it with a new one
댓글 달기
귀하의 답변을 추가하세요
Baudilio Roman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 54
