주요 콘텐츠로 건너뛰기
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
PSP not working after using it with a faulty cable
Hi, I have a PSP without a battery and was playing on it by having it plugged into a powerbank constantly. After some time, the psp started turning off when the cable was at a certain angle. It didnt happen very often, so I just ignored it, but after a while the psp stopped turning on, not even the green light would turn on. I thought the cable has shortcircuited inside, and so I checked 2 fuses on the motherboard with a multimeter, but they seemed to be fine.
Any help would be appriciated, thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Martin Sevela this "turning off when the cable was at a certain angle" sounds like your issue is with the power connector. To replace it or to check it, you'd have to remove the motherboard. Use this guide to get there. The connector would have to be replaced by soldering a new one to the board. that would also give you an opportunity to replace the battery.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Martin Sevela 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 226
