주요 콘텐츠로 건너뛰기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
Water damage, how to fix without schematic?
So I got a lg g2 with water damage for 16 bucks. It's a T-Mobile and it also has a bad charge port. Problem is I don't have a schematic. If I clean it with isopropyl and it still does not work, what could I do? Do lg schematics even exist?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
@gigabit87898 it can be done but makes for a tough job. Yes they do but never search for something like "LG G2" use the model number instead. You should find something like this
이 답변이 도움이 되었나요?
점수 4
댓글 4개:
I found a service manual for a D803 but this is a D801. Would it be the same pcb layout?
@gigabit87898 that is where you have to check the board layout in the SM against the actual board. D801 is a t-Mobile and D-803 is the Canadian Version. It may essentially be the same.
So I fixed this phone, everything works. But, it had custom recovery, rom and bootlogo. How do I reset everything to factory including the recovery?
Fixed it, typing this on it right now.
댓글 달기
답변을 추가하세요
Gigabit87898 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 153
