need new motors or can I/someone repair them?
motor hums but does not rotate
좋은 질문 입니까?
@sueanne1 , Sue, If you are able to disassemble Christmas doll and check that the motor is indeed the problem and not perhaps a stripped gear or possibly out of adjustment. You can then take the motor/gear with you to a good hobby shop and find replacement part perhaps. You could also try a search on the net for replacement part using the make and model of your Doll. If not keen on trying the repair yourself, try a good local small appliance repair shop. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
Contact you to repair these 1950s animated Christmas dolls your ad is kind of difficult
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 372
댓글 4개
Hi,
If the motor hums it may be that the brushes are worn.
Is there a make and model number anywhere on the 'dolls'?
Post some close up pictures back here, perhaps someone may be able to identify them exactly and be of further help.
Here's how 기존 질문에 이미지 추가하기
jayeff 의
LPfaff....I get no movement at all ...It hums hobby shop does not know where I would find them ....It very well might be a stripped gear...I will try to open it and see what it looks like. I do appreciate you help in trying to help me I tried to add photos by the page does not allow me to do that ..info on the motor----2.5 ccw/cw AC 120 v 50/60 Hz 5/6 rpm thank you
sue clinton 의
Hi @sueanne1 ,
Didn't this work for you then?기존 질문에 이미지 추가하기
jayeff 의
sue clinto, sorry the hobby shop was of no help, if these Doll's are very sentimental, perhaps try a small appliance repair shop or clock repairer/maker if able as they deal with this type of stuff also and may have leads to replacement parts or will actually do repair. Below I posted a couple links perhaps you will see a like motor in the pic's and you can click on for details,price,availability. If your dolls have a make and model# you can also google for replacement parts perhaps. Good luck.
https://www.google.ca/search?q=animated+...
https://www.amazon.com/CHANCS-5-6RPM-TYC...
L Pfaff 의
