Help needed putting Instax Mini 8 back together! SOLVED!
UPDATE: PROBLEM SOLVED :)
So since posting my question below I have found the answer to where this piece goes. It's fits in behind where the strap holes are when the casing is on.
Hi, I'm really hoping someone can help. I followed a break down tutorial to fix a camera I'd been given as faulty but there's one part which dropped out when I first opened it and I'm not entirely sure where it should go. I can't seem to find any guides which show you how to put them back together.
The piece is a small with a groove and a hole set off to one side.
Hopefully you can see the piece in the image attached.
I would really appreciate any advice.
Thank you in advance.
Nicola
Update (05/13/2017)
I finally managed to find out where this piece is from, it slides in behind where the strap holes are on the casing!
좋은 질문 입니까?
댓글 1개
I know this is an old post but I have exactly the same problem and I don’t know where exactly you mean! Could you please maybe post a photo?
Shauni 의
