주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
I dropped my phone and digitizer came off
Ok, what basically happened to my iphone was i forcefully threw it because i was really mad, then i saw my IPhone 5 the phone itself and the Digitizer was detached but the ribbon cable was still attatched i could see that when i click the internal home button not the one on the screen theres this white light on the LCD screen but the Digitizer was just pitch black i looked at a few videos to put the screen back into the IPhone si saw a solution i was told to put the screen in the IPhone put my IPhone face down to its back and then i put force on the back, before i did that i turn my IPhone 5 off by holding the IPhones power button the the home button for over 8 seconds it was turned off no light on the LCD, after i done the solution the top right of the screen was not fully in the IPhone, after that, i tried turning the phone on but, no sign of light on the LCD screen, i didn't know what to do i was clueless and when i tried using the vibration toggle i felt no vibration, but, when i tried connecting it to Itunes it detechted my device but it said to connect to (Devices Name) please respond to the device, but i didn't know what to do, my phone had to no passcode so i just thought of clicking the home button to unlock the iPhone but still, asked me to respond..... please help me :(
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
From what you have said, the screen is really in bad condition, digitizer and LCD cables are most likely severely teared which means the screen needs to be replaced for the phone to work again.
If you want to do it yourself you can buy the screen from iFixit here:
iPhone 5 LCD and Digitizer
Guide to perform a screen replacement on your phone:
iPhone 5 LCD and Digitizer Replacement
iPhone 5 LCD and Digitizer 이미지
상품
$39.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Tech Pro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 161
