주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Battery replacement every 2 months
Hi,
I have an iPhone 5s for now 3 years and a half. The original battery lasted as long as 2 years and a half before dying, so I then replaced it by buying new ones on the Internet.
However, the new batteries I bought (3 or 4 for now) only last 2 months before dying too, so I got to replace them quite frequently.
During the first month of use, they usually work great and have a good capacity, but by the second month, their capacity drop very quickly and my iPhone doesn't start anymore.
Do you have an idea on the cause behind this? Could it be the logic board that is getting dysfunctional and draining the batteries very fast? Or am I just buying bad batteries?
Everything else works fine on the iPhone, I even tried a reset to make sure it wasn't iOS's fault but it didn't change anything.
Should I consider my iPhone dead or is it possible I only got bad batteries?
Thanks for your help :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 10개
There are 2 things. Either your iPhone is dead. Or the batteries your getting are very cheap. How much do you pay for the batteries?
Usually around 20 bucks each
Do you buy them from the same person? Or different sellers?
A better question is, where are you purchasing them from?
Have you tried an iFixit sourced battery?
Yea, they are 15 bucks at ifixit, for a genuine battery. Your getting ripped off.
댓글 5개 더보기
댓글 달기
답변 2개
선택된 답변
I would suggest a genuine iFixit battery.
iPhone 5s 배터리 교체하기
iPhone 5s Battery
If this answered your question. Please hit the accept answer button!
iPhone 5s Battery 이미지
상품
iPhone 5s Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
I would recommend using the ifixit battery since they are genuine. You never know with other re-sellers what quality battery you are getting and that is most likely the problem. I have pasted the link below to the part. I hope this helps!
iPhone 5s Battery
상품
iPhone 5s Battery
$29.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
@luffy343, the only way to get a real Apple battery is to go to Apple. Any other source is a 3rd party. However, iFixit has accountability as opposed to other sellers.
댓글 달기
귀하의 답변을 추가하세요
Ottomatik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 145
