주요 콘텐츠로 건너뛰기
Huawei Watch battery requires calibration?
Hello all,
I bought this watch recently, and I noticed that after fully charging the watch, it will drain quite fast (8-12hrs) to 1%, and then holds on this 1% for up to 24hrs more.
This is limiting my experience on it, despite OK overall battery life, because at 15% the watch will activate battery saving mode. So I'm stuck on this mode for like 30 hours of the total battery life span.
I tried resetting the watch multiple times, and I also updated to Wear 2.0 but still the same behaviour.
Is that a known issue with this watch? Is there a way to re-calibrate it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
http://m.huawei.com/kw-enmobile/consumer...
That might help you calibrate the battery, it for a phone but its worth a shot.
Hope this helps! If it did please hit the accept answer button!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Well, this seems to not help, because the watch will turn on automatically when put on the charger so you can't actually charge it while off.
댓글 달기
귀하의 답변을 추가하세요
Omar Qatr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,002
