Why is my self balancing board not charging
I have had my board on the charger for couple days now when I have it on the charger it turns orange but other than that doesn't turn on without charger.
좋은 질문입니까?
좋은 질문입니까?
Camilyn VanDenBloomer, If this problem has just started since getting the new charger and you have a hard time plugging it into your balancing board, the charger could be wrong/defective. If possible try a different compatible charger. Check the charge port for any damage pin/pins, dust debri(pick/blow/clean out), test charger and battery with DVOM to see if charger and if battery does hold a charge(replace battery if not holding charge). Disassemble the board and check for ant loose/damaged/burnt wires/connections / components. The links below may be of some help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=cME9TB0X...
https://www.youtube.com/watch?v=dAWeGXF1...
이 답변이 도움이 되었나요?
Camilyn VanDenBloomer "i had ordered one off amazon and it turned on but only with a charger and just the orange light" it is possible that this is caused by a charger with the wrong specs. You do need to tell us what Voltage/Amperage the old charger had compared to the one you purchased. The other possibility is that the battery no longer holds a charge. For that you would have to consider replacing the battery.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 1,549
댓글 3개
What model is your board? What occurred before this? How long have you owned it? Any issues before this? Are you using the right charger?
Cameron 의
i dont know the model the brand was uber round I have had it since December, 2015, and see well i broke the original charger last year this year i had ordered one off amazon and it turned on but only with a charger and just the orange light i have tried a reseting it but ididnt do anything different and thee can be a wrong charger? it fights in the charging spot and everything.
Cami Vandenbloomer 의
Cami Vandenbloomer uber round or Uberboard?
oldturkey03 의
