주요 콘텐츠로 건너뛰기
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
218 질문 전체 보기
iPad does not charge, despite being plugged in
Hey,
Just last night I replaced the rear casing, battery and digitiser of my iPad 4th gen. The moment I booted it up, the battery was at 26% and everything worked perfectly. I plugged it in to charge, and it dropped to 20. I left it on charge for a while, came back and found no change. I unplugged it and came back in the morning.
The morning comes and I plugged it in again. This time I added a USB multimeter in too and watched the amp draw. Here's what I found.
When the screen is on full brightness and active, it pulls 1.8amps.
When the screen is on lowest brightness and active, it pulls .4 amps. 400mA
The moment I turn the screen off (lock it) wherever the brightness is, it drops to 0.00 amps.
After trying for an hour and ten minutes, it's only taken on 446mAh, and has gone from 20 to 7% (using it to type this)
During the repair I found nothing out of the ordinary. To get the old battery out, the board that connects the three cells did break, so it came out in three pieces. I didn't worry about it though, because the battery was the last thing in the case, the logic board was removed and I was replacing the battery anyway.
Is it a problem with the charging connector, the logic board or even this new battery I've installed? What do you guys think?
Just to recap, it's an iPad 4th gen Wifi. 16gb.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Well, it could be any one of those three. You need to go back and closely inspect the logic board, particularly near the battery connector. You are looking to see if any tiny SMD components have been accidentally pried loose.
I would also inspect the dock flex to see if it has sustained any damage during the repair. And finally, I would test the battery with a volt/multimeter to see if it storing any charge.
Check these things out and get back to us with the results.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Grant Brown 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 232
