주요 콘텐츠로 건너뛰기
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 질문 전체 보기
Low lights turn off when turning on headlights
Low beams turn on normally as do the fog lights. But when high beams are turned on all lights turn off . Tried changing the lights themselves but same problem persisted. Fuses all look fine.
Is there a relay that needs replacing?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi Ed,
When you say "all " lights go out. Do all lights go out including tail and running lights or is it just the low beams and the fog lamps?
If it's just the low beams and fog lamps, that very well may be a normal function of the car. I have an older Jeep Cherokee that does the same thing. Some manufacturers leave the low beams on but shut off the fog lamps. They are different by manufacturer on the setups.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Tail lights and running lights don't go out,it's just the low beams and the fog lights, but the high beams don't come on either, so it's a blackout.
댓글 달기
귀하의 답변을 추가하세요
Ed A 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 260
