Piece of memory card broke inside slot
Hello I inserted the memory SD card inside my canon 80d. It broke inside, what can I do?
좋은 질문 입니까?
좋은 질문 입니까?
Siempremireya, Possibly shake the piece out with with card door open facing down, try sucking it out with a vacuum with small nozzle/crevice tool attached, remove battery and pick broken SD card piece out care fully with tooth pick/metal pin/surgical tweezers or if need be perhaps take into a good local camera repair shop and have them give an estimate to remove broken card piece. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
You'll need to open up the camera to get at the slot. There should be disassembly instructions on this site.
해당 답변은 도움이 되었습니까?
There is no instructions. Also a link to the instructions would be useful.
This problem happened to me 5 minutes ago! I first tried to simply shake putting the slit facing down but it didn’t work. Then I tried vacuuming the piece that was stuck but it didn’t work either. Finally, I used a flashlight and a screwdriver and slowly pooled the piece off of the camera and eventually it fell to the flour.
The camera is still working just fine! so all it takes is a tool and some patience.
해당 답변은 도움이 되었습니까?
24 시간 전: 5
7일 전: 21
30일 전: 62
전체 시간: 3,572
