주요 콘텐츠로 건너뛰기
Repair guides and support for the EOS 70D, a DSLR camera released by Canon in 2013. This camera can be identified by the model number DS126411.
66 질문 전체 보기
Piece of memory card broke inside slot
Hello I inserted the memory SD card inside my canon 80d. It broke inside, what can I do?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Siempremireya, Possibly shake the piece out with with card door open facing down, try sucking it out with a vacuum with small nozzle/crevice tool attached, remove battery and pick broken SD card piece out care fully with tooth pick/metal pin/surgical tweezers or if need be perhaps take into a good local camera repair shop and have them give an estimate to remove broken card piece. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
You'll need to open up the camera to get at the slot. There should be disassembly instructions on this site.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
There is no instructions. Also a link to the instructions would be useful.
댓글 달기
This problem happened to me 5 minutes ago! I first tried to simply shake putting the slit facing down but it didn’t work. Then I tried vacuuming the piece that was stuck but it didn’t work either. Finally, I used a flashlight and a screwdriver and slowly pooled the piece off of the camera and eventually it fell to the flour.
The camera is still working just fine! so all it takes is a tool and some patience.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Siempremireya 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 21
30일 전: 62
전체 시간: 3,572
