주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
직사각형 형태 / 16GB 용량 / 2012년 9월 12일 발표
My iPod won't turn on
My ipod won't turn on. I tried the disk mode whatever and the diagnostic mode. It won't charge. And when i plugged it in the screen just blinks on and off apple logo. It won't respond to the reset. I tried pushing every button and tried everything but it still won't open
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 1개
I dropped my IPod down the stairs when it had no case on and it now happens to not turn on. I tried holding down the off button and the home button but it did not work. Is there anything else I should try?
의
댓글 달기
답변 11개
선택된 해법
  • Connect your device to a computer and open iTunes
  • While your device is connected, force it to restart
  • Don't release the buttons when you see the Apple logo
  • When you get the option to restore or update, choose Update
Or other method similar to first one but it is easy way
  • If your screen is black or frozen, you might need to force restart your device. A force restart won't erase the content on your device. You can force restart your device even if the screen is black or the buttons aren't responding. Follow these steps:
  • Press and hold both the Sleep/Wake and Volume Down buttons for at least ten seconds, until you see the Apple logo.
  • On an iPod touch: Press and hold both the Sleep/Wake and Home buttons for at least ten seconds, until you see the Apple logo.
이 답변이 도움이 되었나요?
점수 22
댓글 10개:
This was not helpful at all. My ipod still will not turn on
의
It worked for me.
의
I held both buttons for over a minute and it still didn't turn on... It wasn't even a week old.
의
My ipod did not turn on what i suppose to do pls. Help me tnx...
의
my ipod is an ipod touch and the home button is broken
의
댓글 5개 더보기
댓글 달기
Press the Power button and home button simultaneously, and hold them down. This may take a while but don't give up really quick. Mine took a while to turn on but it did with this method. Hope this helps, and good luck!
이 답변이 도움이 되었나요?
점수 15
댓글 14개:
Nope ... neither way
의
not working for mine.
의
How long did you have to hold both buttons down?
의
worked for me cheers
의
Yay, it worked for me also! All of a sudden I had the black screen of death.,(That's what I heard some techies call it on youtube). Anywho, I've been using my Nano for exercise, and keeping track of my steps. Great little music player, and step keeper. I am so happy that this fix worked. Thankx guys!
의
댓글 9개 더보기
댓글 달기
mine is, when my ipod is charging it will open, but if you disconnect the charger it will off automatically
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
have the same problem
의
댓글 달기
Well if your iPod is charging and it is on but when you disconnect it from the charger and shuts it will usually mean you have one time left it on the charger way to long and it has killed the battery. Or if it is around 50% charged and you plug it in and charge it, it will mess up the battery. What you need to do is just let the battery totally run out and then wait for 10 or 15 minutes to charge it, then your all set.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yayy it worked for me…thanks Annie Jackson
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It also worked out perfectly for me. Thank you so much....Susie Graham
의
댓글 달기
i have an ipod touch just pops up with the itunes logo and if you update it happens again and if you turn it off and back on it pops back up
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I was just wondering if anyone could say why when I bought a brand new iPod 7th generation that when u put it down say overnight sometimes it will be a blank white screen when I try to go to certain areas for instance settings or my email. I push the restart button and then it restarts fine I have to enter my password and then it’s fine. But my question is why is it happening at all this is a brand new iPod!!! This keeps happening! Ty
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It work for me thank goodness
의
댓글 달기
My iPod is about 3 years old and randomly last night it stopped working. It will not respond to chargers and the buttons don’t respond either, the screens just black. Ive tried just about every type of restart and none of them do anything. My iPod is basically my phone and I need it. What do I do now?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
did you try press/hold the top button and hold the volume down button at the same time?
의
댓글 달기
i don’t feel bad for you…. my name is meane
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I got a white screen when I turn it on and I got a iPod nano generation 7
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Worked for me cheers
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
iries mangao 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 40
지난 30일: 182
전체 시간: 81,930
