주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
After water damage problems
Hi, I think I have a different question to the previous ones. My had water damage but after drying out on airing cupboard for 2 days I switched on and all is working fine BUT it wont allow me to insert the charging plug into the phone anymore, only halfway and seems like resistance stopping inserting plug all the way. The phone is still under warranty but because water damage may not repair free... As I said everything else on the phone is working but my charge is now on 16% and I cannot charge..... Any ideas anyone... appreciated, thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
Get a small needle the clean out the charge port, see if any dust or dirt is in there. If not and it still won't go in, you will have to replace the charge port.
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Thanks for the info... As it was my daughter's phone and she hadn't told me she had put it in rice packet over one night I didn't bother to take a good look into the charging port so when I put a torch light in I could see small piece of rice which was the problem. thanks allll.....
댓글 달기
@gigabit87898 is right. Pretty common for things to get into the charging port on these devices. Be very careful sticking anything into the charging port to clean it. There are 8 pins on the bottom that can get easily damaged. Best to use a tooth pick, only use a metal pick if you know where the prongs are and can avoid them. Use a flashlight to help you see what is in there. Can be lint, can be debris, can be rice (if you used that but not recommend for water damage as it speeds up corrosion process). Do these things and your phone will be up and running in no time. If you need to replace the port after cleaning, here is the link for repair and part.
iPhone 7 Lightning 커넥터 어셈블리 교체
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Problem now sorted thanks, but will keep this handy link. thanks
댓글 달기
As I said everything else on the phone is working but my charge is now on 16% and I cannot charge @hotmail login
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
John 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 35
전체 시간: 343
