주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Wi-Fi 전용 버전의 Apple iPad Air(모델 번호 A1474)입니다. 스페이스 그레이 또는 실버 색상으로 제공되며 맞춤형 A7 프로세서가 탑재되어 있고 16, 32, 64 및 128GB 용량으로 제공됩니다.
Beloved iPad backlight dead :'(
So my iPad backlight has completelystopped woking. I am typing this in it do my spelling my bad as u can bar,et see the screen. At first only some of the lights would not work, it was slinky getting worse and now it had completely stopped working. I will use it to spplr send see if they elk tic it fir free, it now no where ik at die I still s y and dvh vi fud d she get s bee bevel for,
Update:
Here is what it is supposed to say- i think :)
So my iPad backlight has completely stopped working. I am typing this on it so my spelling is bad as i can barely see the screen. At first only some of the lights would not work, it was slowly getting worse and now it had completely stopped working. I will go to the apple store and see if they will fix it for free, if not i will replace the lcd and if still not what could i do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Woah! Lil bro! Backlight circuits can be complicated. I'm certain @refectio with be happy to help you out. I've been biting off microsolderingsupply.com. They have a pretty good selection and should be able to hook you up with the components needed
의
Had screen on iPad 6 replaced but now screen shows shadows especially on white background web pages. Repair shop states new LCD because its a backlight issue? I didn’t have problem until they repaired screen and tablet is only over 1 year old. Could The back light issue has occurred when they replaced my screen?
의
댓글 달기
답변 2개
선택된 해법
Okay, I can officially say this problem is sovled, and I needed not a trip to the Apple Store nor a replacement part. The problem was a connector on the LCD. If you look at the LCD back, on the bottom right there is a fpc connector. When I looked at it, it was half disconnected. I plugged it back in, put the LCD back on and sure enough it works now as I am typing on it. If you have a iPad Air LCD with no backlight, check that first.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Doesn't sound like a backlight circuit failure to me. It seems as though your led back light strip has failed, easily fixable by swapping out the lcd in most cases unless you blew the backlight fuse.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Now I can type normal, I am on my laptop. First I will bring it to apple and see if they will replace the lcd for free since this started before the warentee expired. If not, then I will just replace it.
의
Jonathan, why don't you change the wording on your question now that you can type?
BTW I took a bunch of photos of macs for you, just need the time to get it to you
의
댓글 달기
답변을 추가하세요
Gigabit87898 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 79
전체 시간: 14,252
