주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
voltage output of a battery connector
hi:
is there any standard voltage output thats come out from battery connector (ex: i5c or i5s)
cause i measured battery connector that is placed on iphone 5c pcb with multimeter , and result was 1 Volt and sometimes even less ,not stable , can any body tell me how does U2 charge a battery with 3.7 volt by a voltage output from battery connector equal to 1v and less ???
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The U2 (Tristar) IC is not the charging IC per se. It is responsible for communicating with anything connected to the Lightning port. Once it identifies that there is a charging device, it is the PMIC and the Power MOSFET that actually "charge" (deliver the current) the battery. When the battery is charging, the connector is delivering 4.2V to the battery.
Not sure if this answers your question. Let me know if you need more details.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
yes that was helpful thanks , but when i connect usb charge to lightning port which gives usually 5v and then measuring voltage on battery connector "when battery is out" iam getting 1v and less , and not 4.2v !!
should i connect battery to have 4.2v on connector ?
댓글 달기
귀하의 답변을 추가하세요
wassim505 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 822
