주요 콘텐츠로 건너뛰기
The ZTE Axon 7 Android smartphone was released by ZTE in July 2016. Models: A2017G, A2017U, A2017.
39 질문 전체 보기
touch screen not working
I can't unlock my phone as the top line of numbers on lock screen wont work.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 7개
가장 유용한 답변
This may be an old question, but here is an answer for other axon 7 users:
Your display cable may be loose, so here is a solution without opening the phone. Hold the phone upright with the screen facing towards you, then pinch up and down the right side, you may or may not hear/feel a click, if your problem is not solved, then your screen may be permanently damaged.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If your touch screen suddenly stops respond to your touch, this may be caused by software issues.
Try these steps hope so it will helpful
1. Restart Android Device
2. Remove Memory Card & SIM Card
3. Put Device in Safe Mode
4. Factory Reset Android Device in Recovery Mode
5. Calibrate Touch Screen on Android with Apps
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I tried this but unfortunately when it restarted, I still needed to enter my PIN so couldn't get in to calibrate the touch screen.
댓글 달기
This doc might help you
https://www.fonepaw.com/android-hardware...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There are two bars on my screen that are unresponsive, and I treat this phone like a baby, never had a crack screen, I have a screenshot of which parts
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you have tried all the above its time for a new screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
there it is
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How can I get the ZTE logo that is frozen on my screen to power up or power down
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
kylieandkiwi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 7,424
