주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
it says no sim or sim error
I have the same problem. When placing a call it says no sim or sim error but data works, help please.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 11개
Check and let us know IMEI availability of the device by *#06#. no need to put IMEI number here. just answer yes or no
yes. IMEI is available .
no, there is NIL imei please tell me method to solve it
I also have the same problem it said insert sim card and can't access the network setting as well but I already insert it the sim works in another phone the same model samsung s6 I took it to maintenance shop they said there is no technical failer to it it ok but they can't fix it as they don't understand the problem by the way it works another country sim card
i was using sim card in s6 and then i rest factory data after this in start it show sim card crash but i can use this sin another mobile and any other sim also not working in s6 its show no sim card
댓글 6개 더보기
댓글 달기
답변 4개
가장 유용한 답변
The problem usually has to do with the copper connectors on the sim card getting dirty. To fix it just follow the steps.
  • 1 Pop out the sim card by putting a small paperclip or pin into the tiny hole on the side of your Phone. Push hard so it pops out.
  • 2 Take the card out of the little tray. Remember how it looks when it was in so you can put back correctly.
  • 3 Put some rubbing alcohol on the end of a Q-Tip.
  • 4 Rub the copper side of the sim card thoroughly. Wait a minute to let it dry.
  • 5 Stick the card back in the slot.
  • 6 Problem should be solved.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Cleaning the SIM didn't work for me. I also blew out dust and tried removing and reinstalling the SIM a dozen times. I'm in Canada and I just happened to have an AT&T SIM that I use in the USA. Trying that SIM didn't work either.
Even thought I throught my phone could not be fixed. I took it to a Bell Mobility store where I live in Canada and they wanted to try a new SIM. They said mine looked worn.
The new SIM WORKED!!!
Maybe the AT&T SIM will also work, but only in the US.
댓글 달기
Try to reset network settings by going to your phone setting then open backup md reset nd reset network setting it will help you a lot
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
sim card not work and pta proweaif data not show plz sim not wort problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
it is saying that the SIM card is error
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
emmanuelfranco 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 25,308
