it says no sim or sim error
I have the same problem. When placing a call it says no sim or sim error but data works, help please.
좋은 질문입니까?
좋은 질문입니까?
The problem usually has to do with the copper connectors on the sim card getting dirty. To fix it just follow the steps.
이 답변이 도움이 되었나요?
Cleaning the SIM didn't work for me. I also blew out dust and tried removing and reinstalling the SIM a dozen times. I'm in Canada and I just happened to have an AT&T SIM that I use in the USA. Trying that SIM didn't work either.
Even thought I throught my phone could not be fixed. I took it to a Bell Mobility store where I live in Canada and they wanted to try a new SIM. They said mine looked worn.
The new SIM WORKED!!!
Maybe the AT&T SIM will also work, but only in the US.
sim card not work and pta proweaif data not show plz sim not wort problem
이 답변이 도움이 되었나요?
Try to reset network settings by going to your phone setting then open backup md reset nd reset network setting it will help you a lot
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 25,820
댓글 11개
Check and let us know IMEI availability of the device by *#06#. no need to put IMEI number here. just answer yes or no
Buddhika Mahesh 의
yes. IMEI is available .
Rebwar Khdir 의
no, there is NIL imei please tell me method to solve it
bobby dhesi 의
I also have the same problem it said insert sim card and can't access the network setting as well but I already insert it the sim works in another phone the same model samsung s6 I took it to maintenance shop they said there is no technical failer to it it ok but they can't fix it as they don't understand the problem by the way it works another country sim card
Almaz abiyu 의
i was using sim card in s6 and then i rest factory data after this in start it show sim card crash but i can use this sin another mobile and any other sim also not working in s6 its show no sim card
zohaib gujjar 964242 의
댓글 6개 더보기
