주요 콘텐츠로 건너뛰기
6s와 유사한 하드웨어 사양의 4-inch iPhone은 2016년 3월에 출시되었습니다. 16/64GB 저장 옵션 및 은색, 스페이스 그레이, 금색 또는 로즈 골드로 제공됩니다. 모델 A1662 및 A1723.
1049 질문 전체 보기
iPhone 5s Display works on iPhone 5s but stripes on iPhone SE
I bought a display for an iPhone 5s from ifixit to install it on an iPhone Se that uses the same Display as the iPhone 5s. The Screen works perfect on an iPhone 5s but I get stripes on the SE. I installed an original Apple Display from an iPhone 5s on the iPhone SE and it works perfectly. I don´t understand what´s wrong with the unit? Do you have any explanations for that ifixit? I made short Video from the error just take a look.
Thank you in advance.
Update (06/17/2017)
a little quote from ifixit: iFixit wrote in its teardown of the device. "After a little testing, we found the 5s display is plug-and-play in the SE—fitment, connectors, and functionality are the same. It fires right up."
Update (06/17/2017)
The iPhone Se is 2.Gen, not the first Se that was released.
Update (06/17/2017)
The Display shows nothing during the boot process. After the booted, a double click on the on/off button and it shows the error shown in the video above.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You can't use aftermarket 5S screens on a iPhone SE.
You must either use a original iPhone 5S screen or a original / aftermarket iPhone SE screen.
Aftermarket iPhone 5S screens do not work on the SE as the display is copied from the original screens but not 100% which causes issues with LCD image display working properly on iPhone SE.
They do all plug in no problem physically and fit in properly but like said above.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
@sfsrepair @refectio I am going to convert your comments to question and then send them off to Meta. Maybe the iFixit guru's can shed more light on that.
댓글 달기
귀하의 답변을 추가하세요
Marius Werdecker 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 714
