주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 제조된 iRobot Roomba 655 Pet Series 진공 청소기입니다. Costco 독점 모델입니다.
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
댓글 달기
답변 1개
선택된 해법
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iRobot Roomba 655 Pet Series 사이드 브러시 모터 교체
iRobot Roomba 655 Pet Series 마더보드 교체
iRobot Roomba 655 Pet Series 마더보드 이미지
안내서
난이도:
어려움
2 - 3 hours
iRobot Roomba 655 Pet Series 사이드 브러시 모터 이미지
안내서
난이도:
조정
10 - 15 minutes
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
댓글 달기
답변을 추가하세요
Ben 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 4,368
