주요 콘텐츠로 건너뛰기
The DualShock 4 CUH-ZCT2 was announced in 2016 to replace the CUH-ZCT1 controller released in 2013. This controller is similar to the previous model.
267 질문 전체 보기
L2 trigger wrong input
Hello, I have the following problem.
When I press the L2 button, the analog is apparently triggered up.
If I move the left analogue and press L2 again, the problem disappears, but on some drives it returns.
What could be the problem? What do they suggest?
Here's a video of the problem: https://youtu.be/u6hUOQScQnw
Thank you.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 1개
I got a controller that was doing that issue and I found a permanent fix to this problem. If resetting the controller does not work, the problem is related to the joystick (joystick drift). Sometimes it will just need a clean to the potentiometer and other times, you will need to change it but they are very cheap and easy to change (no soldering require). I found this video that should help you to fix your issue : https://youtu.be/RcIza5Zz8qY
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Henrique Sameshima 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 554
