주요 콘텐츠로 건너뛰기
A Samsung Series 3 PC, the NP300E5C-A09US is a 15'' laptop with a 1366x768 screen resolution. It is a great choice for anyone looking for a lightweight, yet powerful portable computer.
How can I fix my laptop logo/boot loop?
When I start up my laptop the samsung logo comes up and after a few seconds goes to a black screen and a few seconds later it goes back to the logo and it keeps repeating this forever. I have tried many of the common BIOS keys and none of them brought up anything.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Have you tried to use a usb with a bootable window?
Hi!
I have the same problem, and with some googling, it came out that the NVRAM (which is located in the bios) is corrupted. (In my case, it corrupted when I installed linux, as documented on many forums.) Unfortunately, the only fix is to buy a new bios chip and replace it.
댓글 달기
답변 2개
선택된 해법
Take out battery:
Samsung NP300E5C Battery Replacement
Try resetting BIOS:
https://www.youtube.com/watch?v=UXDZXDif...
I would ignore the desoldering part and just remove the CMOS “coin” battery, to the right ,top of video before where he does the desoldering.
This will help with disassembly - clearer than video:
Samsung NP300E5C-A09US Motherboard Replacement
Samsung NP300E5C-A09US Battery 이미지
안내서
난이도:
매우 쉬움
1 minute
Samsung NP300E5C-A09US Motherboard 이미지
안내서
난이도:
조정
20 minutes - 1 hour
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi @gcb140
My bet is your Hard Drive is having problems. You can try to reinstall windows using a recovery disk but if it continues to fail, you may need to replace the Hard Drive.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I am having the same problem but after I replaced the hard drive and RAM. Boot loop, won't even POST, can't get into BIOS. Won't boot from DVD drive or Hiren's through USB.
After you've replaced the Hard Drive, you will need to reinstall an Operating System for the computer to recognize the Hard Drive as a boot device. Follow these instructions to start the process:
https://community.spiceworks.com/how_to/...
You will need a bootable flash drive with your Operating System installer on it to reinstall successfully.
댓글 달기
답변을 추가하세요
Grant B 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 3,524
