주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus ZenPad S8은 Asus의 8인치 안드로이드 태블릿입니다. 2015년 6월에 출시되었습니다. 모델 번호: Z580CA.
Replaced broken screen but touchscreen doesn't work
Hello,
I've recently replaced the screen of a Asus Zenpad Z580CA. Haven't glued the screen on yet, just connected all the cables and booted it to see if it works. No issues with the screen itself, everything looks fine. But I have no response to touch. Anywhere i press there is no response, it's not a few dead zones, the whole screen isn't working. Should I replace the screen again or could it be that something is badly connected? And if so what cables/circuitboards manage the touchscreen?
Thanks in advance for the help!
Update (07/16/2017)
이미지
I have no idea what else I can try...
Help would be greatly appreciated
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
change your screan and try again
이 답변이 도움이 되었나요?
점수 0
댓글 달기
did you insert the touch screen flexible correctly?
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
I assume so.
Which ribboncable is the one that connects the touchscreen?
의
i 'm not sure about the position of the cable itself usually every cable must be fit to the socket just make sure it is well positioned and locked
의
Refitted all cables a few times now, cleaned all contacts as well. Both no luck
의
are you sure the touchscreen is not broken? try another touch screen module hope work
의
댓글 달기
답변을 추가하세요
Ziyedm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 12
전체 시간: 612
