주요 콘텐츠로 건너뛰기
This children's learning tablet was manufactured in 2013. It has a black exterior, and has a medium sized X on the back. Model number: XO-780. No factory recalls.
My screen are broken. I can remplacement?
Hi. My son was broken the screen and i want to repair. Which are specifications?? The flex is 50 pins and i want to remplacement.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@carnalinho check this video for instructions on how to replace it. The LCD is a bit harder to find but every once in a while they pop up at places like this.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Good afternoon friend. I have a xoxo 880 vivitar tablet broken screen lcd. I need BOE 070 screen for Flex KR070PR5T REV: A of 50 pins ... Will it be compatible ??? Greetings 1024x600. But the problem is the flex connnection . thanks... Y dont know a compatible screen
It will be difficult to find the screen the way you describe it. If your tablet is a Vivitar XO7 then go with the screen I linked to. The BOE 070 could be your screen but there are multiple different variance and revision. It will be hard to match the LCD to the flex cable.
댓글 달기
답변을 추가하세요
carnalinho 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 174
