주요 콘텐츠로 건너뛰기
13" 알루미늄 unibody, 2.0 또는 2.4 GHz Core 2 Duo 프로세서.
574 질문 전체 보기
Is it possible to repair my USB port?
One of the USB ports (closest one to the user if using the laptop) does not function. Plugging any type of device, (monitor, flash drive, external hard drive, etc.) does not show up in any form on the laptop.
Is there a way to check the connection and or repair it without replacing the logic board?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
It's according to what has happened to it. As you can see in step 33 of the logic board replacement, it's soldered onto the logic board. If one of those joints has broken loose, it could be soldered back on by an experienced tech willing to do it. MacBook Unibody Model A1278 Logic Board Replacement
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Or... you can just do it yourself, not that difficult actually to do. Just like soldering on any other connector to a board
댓글 달기
This helped fix my usb http://howtofixstuff.blogspot.com/2012/0...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Don't follow that link posted by Misternoname5, that takes you to a repair option for PC users. He could have summed it up by saying "UNINSTALL" your driver for USB then "REINSTALL".
I am in the same boat with a loose USB port. I will attempt the solder technique a report back.
댓글 달기
http://macs.about.com/od/usingyourmac/qt...
my middle usb port sometimes doesnt see anything plugged in but will show power on a flash drive. i reset the smc and that always fixes it. hope it fixes yours
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ryan Barry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 10,456
