Washer filled with water then stopped working
I have a Whirlpool washer/dryer combo in which the washer has stopped working. This happened earlier today. I checked and the dryer still runs. I have unplugged the unit from the wall for a minute and also opened/closed the lid multiple times within a few seconds and that hasn't reset it or anything. I am not sure where in the cycle the washer stopped because I didn't pay attention to the knob before trying to figure out what was wrong with it, but the washer is full of water. I bailed out about 1/3 of the water and tried to 'reset' the cycle to see if it would start to fill up with water again but it still did nothing.
I should probably note that I recently bought some new towels that seem to have shed quite a bit in the dryer (the lint screen was plum full) but I figured if the washer was trying to drain it would at least make some sort of noise.
Any help would be appreciated. I would really like to get this fixed rather than go through the process of buying a new setup.
좋은 질문 입니까?
댓글 11개
@eatsleepindie does it drain when you move the timer? what exact model is it? If it does not drain but everything else functions i.e. agitator moves program timer advances but washer does not drain, I would suspect an issue with the pump.
oldturkey03 의
The water does not drain regardless of where I put the timer. In fact now nothing happens in any of the timer positions. It's an old model so I'm not sure if simply turning the timer to a specific position should start the agitator or start it draining, but neither works. So far I've figured it was the timer itself or the lid switch, but if you think it is the pump then I'll likely order a new one. Is there a way I can test to make certain the pump is the issue?
Al Ridley 의
It's a Whirlpool 'Thin Twin'. Definitely an older appliance, came with the house but I'd much rather fix it than but a new one if possible.
Al Ridley 의
Same thing happened to me today! What was the problem? What was your solution?
Gina Buoniconti 의
@eatsleepindie check your lid switch first.
oldturkey03 의
댓글 6개 더보기
