주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
Backlight and iSight Dead, is it just cable or worse?
I just replaced the screen on my Macbook Pro a1226, but the backlight is dead. I can see the screen images with a flashlight and it works with an external monitor. Also, the iSight camera is dead and doesn't show up in the system profiler.
I'm guessing that I must have damaged the backlight/isight cable and will replace it. BUT, with the symptoms above, is there any chance it is: 1) the inverter; 2) the I/O board; or 3) the logic board?
Thanks so much!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
The flashlight test reveals a non-functioning inverter. With the iSight also out, I'd bet you have disconnected your cables. Why did you replace the screen?
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
The lcd broke, so I replaced it. Turns out the one I got on ebay was broken too, so I replaced it again. Lots of opportunity for me to mess something up, but I think I did a good job reconnecting stuff. I'll check again, but any other ideas? Thanks.
Hook it up to an external monitor to see if all your problems are isolated to the upper. I don't know which guide you used but I recommend this one, because I wrote it: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
댓글 달기
귀하의 답변을 추가하세요
jpkjpkjpk 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 851
