주요 콘텐츠로 건너뛰기
No chime, no startup, no screen but fans and power-LED is on
I have a nice iMac G5 (iSight) on my desk but it doesn't run...
The system does the following:
After pluging in the power-cord diagnostic LED 1 lights on.
After switching it on the following occurs:
  1. NO (!!!) start-chime
  2. Diagnostic LED 3 flashes very shortly (10ms)
  3. Diagnostic LED 2 flashes very shortly after LED 3
  4. the right fan runs normal
  5. the Power-LED (which is see through the case) is on
  6. the optical drive goes in begin state
  7. the HD sprins up and goes in begin state
The system turns exactly after 1 minute all fans in full blow mode...
_______________
What did I have checked?
1. the main powersupply:
- 12V is OK and stable
- 3,3V is OK and stable
2. the other voltages are produced on a combo-board, with the inverter for teh TFT.
I measured the following voltages and they correspond to the printed voltages on the mainboard:
  • 3,3V all
  • 3,3V run
  • 5V all
  • 5V run
  • 12V all
  • 12V run
But there are two lines in the plug on position 1 and 8 (white and gray cables) there is no voltage and they are not GND!
Does anyone can say, what these two cables to have been supposed?
I have numbered the cables of the plug in this way:
_________________________
| 01 | 02 | 03  | 04  | 05  | 06 | 07 |
| 08 | 09 | 10 | 11 | 12 | 13 | 14 |
When you lay down the open iMac with the top towards you and take a look to the cables then the white and the gray cable should be at the left side...
Btw. I've just changed all the ELCOs on the mainboard with Low-ESR-Elcos, but it is the same problem with the iMac!!!
Best regards
Georg
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
+ very studied question
댓글 달기
답변 1개
선택된 답변
Your diagnostic lights indicate that the power supply should be replaced. My service book doesn't get into the specific voltage leads. Here's the part: iMac G5/Intel Power Supply
When replacing note that at first it appears that there is no connector for the power lead running under the logic board but just continue to pull it out till you see the connector.
iMac G5/Intel Power Supply 이미지
상품
$49.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Dear Mayer,
thank you very much for your answer.
But the Power Supply brings exactly the desired voltages!
There are two parts of the Power Supply: This part, you have shown that produces +12V and +3,3V and a second part combined on the Inverter-Board, that produces from the +12V (delivered from the first part) the voltages +5V and so on.
All voltages are like they should be.
Most of the pins of the Power-Connector on the mainboard a print-on with the disired voltages, some don't have a designation...
Once again: thank you very much for your answer!!!
Georg
댓글 달기
귀하의 답변을 추가하세요
GeorgG 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 3,616
