주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3 MB 공유 L3 캐시 1.7 듀얼-코어 Intel 프로세서 (Turbo Boost 최대 2.6 GHz).
Save files from corrupted SSD
MacBook Air A1465 EMC2558
Hi.
MacBook air doesn't start. Disk Utlity from Recovery gives errors while trying to repair (Missing thread record). I want to copy files with Ubuntu LiveUSB but can't access files. The username doesn't show in users folder.
How Can I save my files?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
I think you'll need to rethink how to recover the files here. Ubuntu LiveUSB by default won't access the Mac file system so it won't show you the files you are trying to gain access to. Yes, you can make it work but it's a bit late here for that. Here's how one person did it: Ubuntu installation on USB stick with pure EFI boot (Mac compatible) I my self have never done it so I'm not sure even this works to the point of being useful here. It also won't gain access to FileVault2 encrypted drives or folders.
OK what to do??
You'll need a second Mac system to either connect to your MacBook Air via Target Disk Mode or remove the SSD from your MacBook Air and place it into an external case and connect it to your good Mac via USB.
The other possibility here is to create a bootable Thunderbolt or USB drive and then use it to boot your system so you can salvage the files and as well see if you can save the SSD (reformat it & install a fresh copy of OS).
Sadly, you'll still need access to a second Mac to prep up either the Installer drive or the external bootable drive. Frankly, you'll likely need both!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Vardan Hovsepyan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 703
