iPhone 6 plus display very hot after repair
I have just changed my iPhone 6 plus display, i changed the full assembly. The iPhone is definitely very hot at the right hand side of the display towards the top. Its heats up in the area after seconds of light use. Only thing i can think of is maybe front camera and that i should transfer over original camera. Can anyone think of anything else...
Also is there any tricks to get fingerprint working again. I have re-used original home button but saying failed when try to activate it...
And thirdly the display is on quite firmly and pushed down as tight but if you look very closely or run your hand round edges you will see the display is slightly raised from the chassis. Ive seen this on a previous repair and inclined to think these aftermarket screens are not just as good a fit as originals...
좋은 질문 입니까?
댓글 1개
UPDATE, I've just swapped over front facing camera assembly but still remains hot and also battery is def draining quicker....anything else that could be causing these issues,
Aidan 의
