주요 콘텐츠로 건너뛰기
PlayStation 3 wireless LED controller made by Performance Designed Products, LLC with model no 064-015-EU-BL.
9 질문 전체 보기
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
how u dont use the usb for ps3 and pc
댓글 달기
답변 1개
가장 유용한 답변
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
댓글 달기
귀하의 답변을 추가하세요
Ty Smothers 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 11,871
