주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Performance Designed Products, LLC에서 제조한 모델 번호 064-015-EU-BL의 PlayStation 3 무선 LED 컨트롤러입니다.
USB Not connecting to PS3
My PS3 afterglow controller has always worked great but recently the USB drive just stopped connecting. Now whenever I plug in the USB to my system it just continuously blinks. My USB ports are working fine because I can still charge other controllers and the actual USB to the controller connects perfectly fine to my PC just not my PS3. So I have no clue what the issue is and I don't quite want to get a new controller yet because it seems like this one still works, it just isn't connecting to my PS3 right now. It'll be great if someone could answer this
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
how u dont use the usb for ps3 and pc
의 공유
댓글 달기
답변 1개
선택된 해법
Check the pins on the controller's end of the USB. Are any of them bent or dirty? A short due to a bent pin or dirt blocking a connection could be causing the issue. It also would not hurt to give the controller's usb pins a cleaning with contact cleaner to ensure a clean connection. I would also recommend checking the cable itself, to see if their are any kinks in or exposed wiring. If that doesn't it fix it, then its most likely a problem within the controller's PCB board.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
What is a pcb board and how can i fix it or clean it so i can get the controllers to work
의 공유
댓글 달기
답변을 추가하세요
Ty Smothers 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 12,723
