주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
No life after screen replacement
So we fix around 50 iPhones a week and for the first time one died on us. We fitted the screen, passed back to the customer and was fine, after an hour they brought it back without any life at all. We have the customer a loan phone while we look to sort the issue.
I've done all the standard diagnosis tests, screen, battery, charge port, backlight but absolutely nothing. There is no heat going to the board at all and is totally non responsive.
It wasn't bent or beat up, just a simple crack in the screen.
We are just training on board level repair but not enough to say where the issue lies, at the moment it's simple backlight repairs. Can anyone point us in the right direction for diagnosing a possible cause.
TIA
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Then this will be your big chance ;>)...
Because you have already ruled out all of the modular components but don't really have any other leads, I like to recommend that you start at the beginning. Do you have access to a USB Ammeter? This will allow you to see if the phone is drawing any current.
Always start with the main voltage rails...PP_BATT_VCC & PP_VCC_MAIN. Check to see if they are shorted first (with battery disconnected) and then check the voltages under power. If those look good, move onto the PMIC (U1202) and start testing the voltage rails it produces. You should also do a thorough visual inspection to see of anything is obviously wrong.
So start probing and then report back with your findings so that I can give you more detailed suggestions.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Wes 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 55
