주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Should I replace the logic board on my iPhone 6S?
The iPhone 6S was working fine the night before but in the morning was dead.
Tried doing a hard reset, the screen flashed for 5 seconds and went dead.
Apple store diagnostics said phone is not repairable.
Took to a cell phone repair shop and tested with new battery and display - it did not come on.
The only option is that the logic board could be out.
Should i attempt to fix logic board? Is there anything else I should try before I fix the board?
Thanks
Dan.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The iPhone 6S is still a very valuable device. I would certainly consider having the Logic Board repaired. Most shops that specialize in micro-soldering use a no fix/no fee pricing model so you don't have much to lose. You can check out my profile for more info or search google for other shops that also do no fix/no fee..
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Can I mail it to you? Live in US..
Have you been charging with a non original charger? I ask because the Tristar (USB Charging IC) is known to go bad when you do. You have checked the Charging port I assume? Minho is second to none when it comes to iphone repairs and is well known here on Ifixit as the "Iphone God", lol...You can search for local business that perform Micro-soldering and are reputable but they are far and few between.
@njayaram, sure, check my profile if you want to reach out to me directly.
As @teetopp mentions, you may find a good micro-solderer in your area if you Google "micro-soldering your city/state/region". There are several awesome micro-solderers out there, some of them are active on this forum (including Michael), others use different avenues to share their knowledge (Youtube, Facebook etc.). As for me, I bleed and hurt like everyone else...so I am no god :-).
댓글 달기
귀하의 답변을 추가하세요
Nan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 196
