주요 콘텐츠로 건너뛰기
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 또는 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz 또는 Core i7 2.8 GHz) ID iMac11,1
467 질문 전체 보기
iMac with black screen
Hi,
My iMac makes the chime boot and the fan is running but the screen won't turn on. I conect it to an external monitor and it shows me a white screen with a question mark inside a folder and it doesn't run the OS..
Is there a solution for this issue?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Sounds like you have two problems. The first one is that it can't find a valid operating system. Fixing this one may rectify the second problem so go of it first.
Leave the external monitor plugged in for now. Boot up holding down the Option key and see if you can select the Repair Partition. If so run Disk Utilities on the drive. If nothing shows up, then boot from your original system installation disk, go to the second page of the install when the pull down menu appears and run disk utilities. If that fails you will need to replace the hard drive. Meanwhile tell us if the internal LCD lit up when booting from the DVD.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Gio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 378
