주요 콘텐츠로 건너뛰기
Guides for the LTE version of the iPad Mini 3. Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
iPad Mini 3 LTE Front Panel Replacement adhesive suggestion
There is no mention is using any adhesive during the installation of the new panel. I know that there are many different adhesives available for different purposes. I assume that some adhesive needs to be added. Please correct me if the original, softened, adhesive will remain and sufficient to properly hold the new panel, or provide some useful suggestions for what adhesive to use. For example: what about Tesa double-sided 4mm tape?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 1개
선택된 해법
To do a proper repair, you should remove the old adhesive. Most replacement digitizers include adhesive strips already installed. IMHO, the adhesive that is pre-installed is not very good quality and the digitizer will generally start lifting with time.
If you keep the old adhesive, it will only work if it is still fairly intact. More often than not, much or most of it is removed along with the digitizers.
You also need different widths of tape to do a roper repair. If you are a shop, then getting rolls of Tesa Tape in varying widths is a good option. Otherwise, I would get pre-cut adhesive from a reputable supplier like BlowerTech Adhesives or TapeTemplates. For a one-off repair, removing the pre-installed adhesive on the digitizer and applying a pre-cut template is the preferred method.
Replace a screen digitizer compatible with iPad mini 3. Includes installation adhesive. 이미지
제품
iPad mini 3 Screen Digitizer
$34.99
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
You "point" to the iFixit replacement Front Glass product and indicate that you think that the quality of the adhesive supplied in the noted Front Glass replacement is "not very good quality". So you would prefer to NOT use the iFixit Front Glass product with its supplied adhesive - correct? You would remove the replacment product's adhesive with something else - correct?
Yeah, that's basically it. I have used iFixit digitizers and the quality is very good and the service/customer support is outstanding. I remove the pre-installed adhesive and install adhesive from BowlerTech. This is true regardless of where I have ordered digitizers.
This is my business so I only use the best parts I can find. If iFixit sold a digitizer without adhesive, that's what I would buy because it would save me the hassle of removing it. From an iFixit perspective, their main audience is DIY fixers so it makes sense to pre-install the adhesive...iPad repairs are already hard enough.
댓글 달기
답변을 추가하세요
Jim Dutton 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 142
