주요 콘텐츠로 건너뛰기
다양한 TV 브랜드 및 스타일 안내서 및 지원.
9064 질문 전체 보기
Why are there vertical striped lines on the tv
Hello, I turned on my samsung ue50f6500sb tv tonight and all I have is vertical striped coloured lines on the 55" screen - I live alone so no one went near it. Its wall mounted and has never had any issues before. Can anyone help me? I'm slightly techie so I may be able to carry out some repairs if necessary.. I took the back off the tv and messed with the board which has the hdmi ports etc and it makes no difference. Any help at all or ideas would be greatly appreciated.
Thank you, Phill
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
@phillominal that is a big depends. Depends on what those stripes look like and how they are running. Post some images to let us see what your screen dispalys. Use this guide 기존 질문에 이미지 추가하기 for that.
Most common cause for any vertical stripes would be the T-con board
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You have to replace the whole lcd
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
lyle_mcc ' what do you base your answer on?
댓글 달기
귀하의 답변을 추가하세요
Phillip Melia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 169
