주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
597 질문 전체 보기
Ifixit replacement battery doesn't fit in MacBook Pro
Recently I just bought a replacement battery for my MacBook Pro 15" Unibody Mid 2012 from ifixit and the thing is that it doesn't fit properly. And i don't wanna try to force it in because my previous battery which came with the laptop 5 years ago slides in perfectly.
The previous battery is A1382 10.95v/77.5Wh
The new battery is A1382 10.8v/77.5Wh
I don't know if the voltage is why the battery doesn't fit. I was expecting a 10.95 when i ordered it from this site.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
This question was migrated from http://www.ifixit.com/Answers.
This question was migrated from http://meta.ifixit.com/Answers.
댓글 달기
답변 1개
선택된 답변
This model number is for the battery for 15" MacBook Pro models (Unibody, Late 2011/Mid-2012).
I think you may be trying to insert it incorrectly. The outside edge must be inserted first. Does it look identical to your previous battery? here's how to install it: MacBook Pro 15" Unibody Late 2011 배터리 교체
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
yup it actually fit. thanks for the help. And so what about the voltage. my original battery had a 10.95v but this one is a 10.8v. Should i call fixit about it and have it replaced or does the voltage not make a difference.
@ekiflom small variations in voltage like that don't mean squat. They also average about 94% of the listed maximum charge on any new one.
Okay. I have read a few forums that after properly installing the battery there is something that you have to do with charging it and letting it drain.... something like that. Is there a guide that can show me on that or can i use the laptop right out of the gate?
Let it run all the way down then fully charge it.
Okay thank you for all the help.
댓글 달기
귀하의 답변을 추가하세요
Eyob Kiflom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 9
전체 시간: 869
