My yoga 900 wont turn on and the charge light not lit.
I stupidly bought and plugged in a cheap power charger to my Yoga 900. It was going to be my portable back up.
It immediately shut the computer down.
The charging light was NOT lit on.
I then tried to used my OEM charger. The light still doesn't turn on.
I pulled the back cover off and took the battery off. Held to power button for a minute to dissipate the capacitive charge. Reconnected the battery. Still NOT on. Charging light still NOT lit.
I heard that the CMOS may need to be replaced?
I dont think this yoga 900 comes with one?
The manual said the system board needs to be replaced?
Update (07/31/2017)
It looks like the power port connects directly to the system board.
See attached pictures from the Lenovo Hardware Manual
좋은 질문 입니까?
댓글 5개
When you took it apart was there a daughterboard beside the motherboard with the power port on it? Or was the port connected to the motherboard?
Chase 의
Sunny 의
did you solved somehow?
julian pablo Villarpando 의
I have the similar problem. Neither it charges nor boots. There is no sign of life at all! As warranty is over, I want to fix myself. I just would like to know possible solutions. Replacing power jack cable, battery or etc.
ahmet ozkaya 의
I also did the same mistake, bought cheap charger not to carry to office everyday. I don't want to invest more unless I'm sure changing power port will the problem. (I dont think power port is the problem, because it seems only a wire).
ahmet ozkaya 의
