주요 콘텐츠로 건너뛰기
Samsung smartphone released in January 2016. Model SM-J320
20 질문 전체 보기
How do I fix a black screen?
I had recently gotten a samsung galaxy j3. I accidentally dropped it into a pool, and dried it, I waited a few days and after a while, it turned on. the screen is illuminated, but stays black. Ive tried everything, even a reset but the screen stays black, The phone vibrates and the flash stays on when charging, but nothing happens screen wise, Do I need to get it replaced?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I recently got a samsung galaxy j3, incidentally dropped into water, i dried it up to a week to ensure its totally dried. I put the battery and power it ON, it turns ON. Every thing functions perfect, but there is no light on the screen (dark), Its charging well. Please what do I do? can someone help..
댓글 달기
답변 2개
선택된 해법
There is a tricky part here. You dropped it in water, therefore it needs to get cleaned out immediate to prevent corrosion. This can be done with 90% isopropyl alcohol
There is still a chance the phone may work after cleaning, so don't give up!
If you cleaned the phone and issue still appears to be the same, then you will most likely need to replace the screen. Not sure if you have the exact model you posted but here is a breakdown for the a J3
If you're not comfortable in this realm, just take it to a shop and inform them it was dropped in a pool.
Hope this helps
이 답변이 도움이 되었나요?
점수 2
댓글 달기
my phone is brokekin
Update (09/02/2018)
its my screen my phone is broke
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mikey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 9
전체 시간: 3,119
