주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2396 질문 전체 보기
Replacing iPhone 4 front assembly piece by piece?
Hello everyone, I made the very foolish mistake of rushing in and purchasing just the front glass, later on did i realize this mistake.
So I then purchased a front glass with digitizer.
(but no lcd) I thought they were the same thing =_= (I know noobish right?)
So my question is can I just purchase a compatible lcd screen and bind it to the front glass w/ digitizer?
or is it another waste of money and I need to buy front glass+lcd+digitzer pre assembled?
Thanks for any help, tips, or advice.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
There are those of us on here that say it can be separated with a heat gun and lots of luck and than there is the school of thought that realizes that the easiest and safest way to replace the LCD is to do it as a single unit. The glass and LCD and Digitizer are adhered into a single unit. Hope this helps, good luck
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hey kvnta,
I heard of people that managed to disassemble the Display Assembly (although not without breaking the whole thing to pieces), but I don't think you you can buy just an LCD and then put everything together with a little glue. Moreover, even if it were possible (which I'm sure it isn't) how would that look like with all the glue in between the different parts...
Nope sorry pal, that was just a waste of money.
Here is the right place to get a replacement for your display assembly:
iPhone 4 (GSM/AT&T) Screen
Kind regards,
deSteini
iPhone 4 (GSM/AT&T) Screen 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Thanks for the answer. I was looking at this
http://cgi.ebay.com/Replacement-LCD-Scre...
Im thinking that the touch screen lcd is a bit longer then the viewable screen so maybe using thin strong adhesive strips to bind the lcd to glass. I would put it at the top by the speaker and at the bottom just above the home button, and possible on the sides if there is enough room without it showing.
do-able, or more senseless dreams. :[
I think your phone would look like my old flipphone that is truly held together by electric tape and double side tape....:) I think you are asking for more trouble and spending more $$$ than if you cut your losses and get the whole new set. Just my 2cents :)
I totally agree with oldturkey03.
댓글 달기
you can do it your self there are a lot of videos of how to do it on youtube just buy the part at buy this part good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
How many have you done and how easy do you think it is?
댓글 달기
귀하의 답변을 추가하세요
kvnta 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 3,367
