주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
북미 지역에서는 Canon EOS Rebel XTi로 알려진 XTi는 2006년에 출시된 10.1 MP 센서를 탑재한 보급형 Canon DSLR입니다. EOS 400D 및 EOS Kiss Digital X로도 알려져 있습니다.
Auto focus doesn't work...
My camera has been working great until recently, the AF stopped working, in any mode M or P or TV it keeps trying to auto focus goes back and forth and the #9 lights up on the right side but when I push to shoot nothing happens. In M mode I have no problem., tested the other 2 lenses I have, same thing, checked batteries, charged, I even replaced the lithium battery, I reset it to new, did all this before my next step. Curious me I removed the camera lens and took a look inside, cleaned it and then put back the lens on AF mode and it started working, but now the pics are coming half black, so I went back the and the mirror was open, closed them together and then again it went back to the non working AF.
This camera has been working fine except for the "remove the CF card" now and then, it takes amazing pictures and I'd hate to replace it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Old Canon DSLR camera tech here. I know I'm really late to the game (by about 5 years), but if you still have the camera and want to try cleaning out the AF unit, it is inside the camera, on the bottom of the mirror box. IIRC, the reason the camera works fine in "M" (Manual) mode is because the autofocus unit is not engaged while in the "Manual" mode - your eye and judgement are used for focusing.
Please do not attempt any de-soldering unless you're very familiar with the process - you could ruin the electrical lands & traces, ultimately ending up with a dead camera...
Take any lenses or covers off the EF mounting ring, move the mirror assembly up and secure it in the "open" position (use a piece of tape or hold with a finger). Then turn the camera upside-down, and blow short blasts of air into the AF unit (you should see a diamond-shaped configuration of holes resembling the 9-point autofocus you see through the viewfinder). Don't use any liquids (even isopropyl alcohol) in an attempt to clean it - only air!
Once you think it's been cleaned, put it back to its normal configuration and try again. If that doesn't work, you might try a few more times, but the AF units can go bad - I've replaced more than my fair share. As far as I remember, they are replaceable and do not require any special calibration. If you can source an AF unit for the camera, please follow the disassembly instructions already here on the site, to the point where you remove the tripod mount. After that, you should see the boxy black plastic of the AF unit. I believe it's held in with two screws, although the lead cable will also need to be disconnected from the mainboard. Try to get the replacement unit as perfectly squared as possible to ensure proper AF function...
Or, contact Canon and see if they will fix it, and how much they'd charge.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Gabriela Westrup 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 29
전체 시간: 865
